Vintage Boat Guy
Thread starter- Joined
- Oct 16, 2013
- 162
I got this old Johnson outboard from a neighbor's shed a few years back and they told me it hadn't been used since 1981, it's a RXE-13 33hp Johnson 1965. I was told it was only used a few times a summer on the weekends from 1965 - 1981 and it looks like brand new. Paint is on all the bolts and I imagine its never been apart before. I recently bought a Glen L TNT and decided that this old 33hp would be perfect for the boat. I got the old girl running on the stand and it ran fine with the original fuel pump. I changed the impeller and cleaned out the carb which was already spotless and I changed the lower unit oil and installed new B6S NGK sparkplugs. The engine had great spark and ran well on the stand although we had to give her some throttle to start. I've since put it on the boat and it doesn't stay running unless it's in gear and when I adjust the high speed jet it does very little and the high speed is almost closed before it will pick up at all wide open. It seems to be running on only one cylinder, but I checked by pulling wires off while running and it is running on both cylinders. I have a 1957 35 hp as well that has compression relief valves and was wondering if the 33hp has the same valves built in the head although it has no built in compression relief system. I was also wondering if this is a symptom of a bad head gasket. I know this motor should jump on this little boat and my 1952 25hp will out run it on a heavy 16' cedar boat full of water, any ideas?
