1965 Johnson 3HP JW20B -> What gearcase oil should I use?
andrewsilver
I changed the gearcase oil in my little 3hp motor with Pennzoil 75W90 fully synthetic gearcase oil. That's what I use on my Mercury sterndrive, and it says it's good for all gearcases.
My Johnson "owners" manual for the 3HP Johnson says to use OMC Type C gearcase oil, but it doesn't give the specification of what that is.
Thank you.
kbait
Re: 1965 Johnson 3HP JW20B -> What gearcase oil should I use?
Just so it's marine application gearcase lube, you're good to go.
andrewsilver
Yes it is Pennzoil marine gearcase oil. So I should be ok then.
Daviet
You should be good, I usually use a marine 80/90 weight oil, but you should be fine.
