Re: 1965 Johnson 75 HP water impeller
I got the motor running great, but I'm only getting a sprinkle out of the blow hole... What kind of volume of water should this be putting out at a little above idle? <br /><br />Also, I'm still getting water in my lower unit... I've replaced the two seals below the impeller housing and the one about the impeller housing. I used silicon between the lower unit housings and between the lower unit and the exhaust tube. The impeller housing has two bolts sheared off.. would that cause it, or am I looking at a bad prop shaft seal? IF so, how hard is the prop shaft seal to change? <br /><br />Additionally, I've found out its a 100HP from around 1966... <br /><br />Thanks, Cory
