CaptainHook
Thread starter- Joined
- Mar 18, 2010
- 310
I just picked up a really nice, clean 1965 Johnson 9.5hp. It has great compression, new water pump, brand new coils, points, and plugs. Starts 1st pull cold. Complete and really clean!! Got it for $90 and it runs great, that is unless you try and idle it.
It was "coughing" or something (I don't know how else to describe it) all the time. I swapped the carb with one from a 1973 9.5 parts motor I have and once I got the mixture set it was perfect. Ran it in the tank for about 30 mins with no issue.
Pulled the fuel line to let it run out and it started doing it again. Now it is fine with a little throttle or with the choke half closed but at normal idle it keeps "coughing" and will stall. Any ideas?
