Cohokiller74
Thread starter- Joined
- May 1, 2010
- 5
Just some general questions for the ones with lots of experience out there. I have the above outboard. Got it as a hand me down from Grandpa. Don't know the history of any maintenance. Has run good for the last couple years with new plugs and gear oil change. Last weekend had some problems. Noticed bogging down, rough running, lower rpm. Found a leak in the fuel pump, fuel leaking out a small hole in front of carb, and getting water in the gear oil. Found a crack in the lower gearcase (part with the skeg) I am planning on getting the maintenace and repair manuals for this era. The big question is which years are these parts interchangeable? I know the motor is essentially the same for 20+ years. Also are carb kits, fuel pumps kits, water pump kits, still available? I am pretty sure I will have to use some JB weld on the gearcase since it may be a bit difficult to obtain. Any help would be great since I want to get back to fishing
