Re: 1965 Johnson 9.5 water pump?
As ezeke suggests, it ain't gear oil. It's oil that you put in the gas that has gone through the engine and done it's job. It then goes out the exhaust...into the barrel (or lake).
Two-stroke engines only use the oil once. It is then partially burned (smoke) or dumped.
