Obvious0ne
Thread starter- Joined
- Nov 25, 2009
- 27
I've been wanting a Lightning for awhile, but they are hard to come by in this part of the country (central Texas). When I found a cheap one for sale in Tulsa, System-F and I ran up there and snagged it.
It wound up needing a bit more love than I had hoped for, but it's not all that bad.
Original pics from the Craigslist ad:
The Lightning is a one-design racing sailboat designed in 1938 and still somewhat popular (and still raced) today. It seats 4 comfortably and is raced with 3.
It turns out that this was one of the first foam core fiberglass boats (hell, it wasn't too far from being one of the first fiberglass boats, period... 1965. This is back when it was called "Fiberglas"). It looks like it was built out of wood and then covered in fiberglass, but the planks are actually foam sticks.
I found a little plate at the rear of the centerboard trunk that says Martin Weir and Co and something about Ravon Fiberglas. Check out this article I found when I googled that:
1963 Popular Mechanics, Plastic Planks
List of things that need fixing:
1) General trailer fixing up (paint, tires, bearings, registration etc)
2) The trailer only supported the boat by two sideways 2x10s shaped like the hull - except the forward one wasn't shaped very well and most of the weight of the boat (700lbs+) was resting on a small part of the center chine... this put a pretty good crack/break in the hull.
3) Two other minor cracks/dents in the outer hull (one in the bottom, one up near the rub rail)
4) Lots of soft spots in the floor on the inside. Cracked glass repair around scupper
5) Needs new floor boards
6) needs deck reinforcement
7) Teak trim and interior pieces need prettying up and in some cases repair/replacement
8) Interior and exterior paint
9) centerboard needs sanding and paint
10) Seats on the port side are very weak - need to remove (which will require cutting) and reinforce them
11) scuppers may leak - one was taped shut
