1965 merc 650 hp?
BANDIT2847
could someone tell me the true HP on a 1965 keikhafer merc.650 thunder bolt four short shaft ? thanks
Re: 1965 merc 650 hp?
Ayuh,.... 65hp....
southkogs
Don'tcha' kind of wish they could pack 650PH into those things though? :D
Bob_VT
Mercury rated at the prop before any of the other manufacturers and often under-rated the HP........
With that said...... a 1965 motor "may not" be putting out the full HP due to it's age. Parts are tough to get for those older Mercs :( and normally the wiring is the first thing to need replacement
Texasmark
I know the rest of the pack did it around '84 per some kind of govt. mandate. Just when did Merc start?
I recall, over the years, even back in the late 50's the Merc 12 hp (Hurricane?) 2 bladed prop would run circles around my 10 hp Scott Atwater. Later the red band 125 towers in the early '70's would run circles around my OMC 125. I finally got tired of it and went with the brand.
Mark
jbjennings
I believe that is the 4 cylinder 65hp and it's a darned powerful motor according to my dad. They were good motors. I'll bet it's every bit of 65hp at the prop.
I own 2 early 70s 3 cylinder merc 650's, and according to my dad, they're not nearly as fast and powerful as the earlier 4 cylinder models that he once owned.
