1965 Mercury 350 prop
Strychn9ne
Hey all, I'm looking for a replacement prop for my boat and having a hard time with it. It is a 1965 35HP, 11 spline. The number on the prop is 48 38094a1 12P, I believe it's a 10 3/4 x 12" prop. Through hub exhaust as well. The hub is blown out of it (Slides on the shaft) and the blades are pretty bad. Are there any replacements out there? I think I'd be OK going up or down 1 on the pitch. The boat is a Starcraft Siren 14' fiberglass, it's very light boat. Currently it runs OK and does about 20MPH, but takes a long time to plane out.
Fun Times
48-38094A1 is the OEM part number from Mercury.. It is a 12 pitch.
The OEM part number can be found in the chart seen below that fits your engine model. Can't seem to locate a in stock OEM part number through iboats at the moment and I believe just about one of the only places you might be able to find something to fit is here, http://propcopropellers.com/mercury_Outboard_Propellers.htm
If Using Uncupped Propellers, Use Cupped Propellers With 2" Less Pitch. Boats With Power Trim May Use Same Pitch.
AL = Aluminum, APPL = Application, C = Cruise, HL = Heavy Load, LL = Light Load,
MAT = Material, SW = Semi Weedless, SS = Stainless Steel, W = Weedless
QRJ-T 4-Blade Gives Better Holeshot, Less Torque on Steering, Better Boat handling, Lower planing Speeds.
"SP" Special Performance * Cupped Propeller
35-50 HP11 Tooth Spline
Thru Hub Exhaust
62 Thru 69
C
AL
10 3/4 x 10
3
M35-10P
48-33774A1
P13B$120.00
C
AL
10 3/4 x 11
3
M36-11P
48-38098A1
C
AL
10 3/4 x 12
3
M37-12P
48-38094A1
C
AL
10 3/4 x 13
3
M38-13P
48-38090A1
LL
AL
10 3/4 x 15
3
M40-15P
48-38086A1
Strychn9ne
That looks like the one! Now, is there anywhere I can find a new thrust washer? The one on the engine now is pretty worn. Also, I'm not sure if this engine came with a lock washer behind the prop nut, but there isn't one on there. The whole lower unit came from a salvage yard, so I'm not at all sure how it's supposed to be set up.
Fun Times
http://www.mercruiserparts.com/350
http://www.mercruiserparts.com/bam/subassembly/32747/435/17
8038859A1 THRUST HUB AND WASHER ASSEMBLY ACT
$24.16$23.721,1,1,1
8112-31992 --WASHER, CUPPED-THRUST HUB ACT $5.40$5.271,1,1,1
8212-32007 WASHER, SPLINED-PROPELLER SHAFT ACT $5.24$5.141,1,1,1
8311-82671120 NUT, PROPELLER31990SS/ACT
$9.45$9.28
Strychn9ne
Wow, thanks for the info! That will definitely help. I forgot to mention, mine is serial number 1838819. So I ordered #70 through 74 on the gear housing assembly page 2 list. There was also a backing washer on there. I'm not sure I need everything, but I should have all bases covered now. Now all tha'ts left is to stack it all together I guess. So, if I'm looking at it properly, it goes backing washer first, then thrust hub and washer assembly, then prop, then cupped washer, then splinder washer, then nut. Mine was missing a few parts from that list, so I'm not entirely sure how it goes back together being so different from modern assemblies.
Strychn9ne
Well I got it all put together. The thrust washer on there looks different from the one I bought. It's made of brass and is cupped on the lower unit side. There was no backing washer, and the lower unit and prop wore into each other about 1/8" from my little test run last week leaving a little gap between it and the prop face. With the new one installed, the backing washer was not needed and everything lines up now. I used the 3 parts linked by Funtimes, and the old thrust hub could be re used with a backing washer also installed. Hopefully this will work well. Next it's time to retire this dinged up prop with a new or old stock one. Thanks for the help!
GA_Boater
The link Fun Times gave to Propco is the only place to find a new 11 spline prop. I got one earlier in the year and they are good people to work with and the prop is well made.
Strychn9ne
Glad to hear a good report. I found a used bronze 12 pitch one that will work for now, but definitely want a new one. Do the Propco ones have the same rubber style hubs as the old props or do they use the newer removable ones?
