FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
How do i tell if the water pump is working? And if its not how do I get to the water pump to change the impeller? Any help will be appreciated thanks you guys are great.
As most folks here will tell you ,You really need a service manual since you havent ever done one before. There are alot of previous threads that may help. If no water is coming out of the engine as it runs the pump isnt working. It needs to be cranked in a barrel and not connected to muffs to really tell.Unless you know for sure it was replaced recently you need to put one in. They dont last for years.
I'm sure it has not been change it has been setting for a couple of years before I bought it. I have a manual on the way. I was hoping to to get some info on how to do it? I was hoping to get it fixed before the 4th so I could use it. I will search the site to see if I can find some info thanks.
I got the impeller installed tonight it was pretty easy. I also drained the lower gear oil it had a little water in it is that normal after setting after setting for two years? I did a leak down test and it didn't loose any pressure so i was wandering if its just condensation from the two years of setting?
I had the same problem and when I changed the impellar still no water was told to blow air through the nipple were the water comes out and sure enough fixed the problem.
Was told that even a spider can clog it up.
