narnsmarnq
Thread starter- Joined
- Sep 7, 2010
- 9
Hello All,
I was reading a lot over the last couple of days, but can't seem tio find a answer so...
I got an (almost) free 1965 Sportwin 9.5. Throttle inkages were all seized, coils are shot, etc. I have a repair manual, so I'll muddle through and see what the total damage is.
However, I have a question I can't find a answer for in the repair manuals, the shifter won't budge. I haven't had the lower leg apart, but the prop staft truns freely and the engine will pull over. I am wondering if there is some kind of interlock that prevents shifting, a button that has to be pushed, anything obvious that I may be missing that would prevent shifting. The shifter is the flat horizontal handle kind that moves up and down, not the vertical shifter.
Should the above not be the case what would be a nesxt reasonable step in my investigation? I'm not sure how the shifter works (I think it employs a simple vertical movement of the shaft), could the drive shaft be seized somewhere? Is a complete teardown in order?
Any and all help appreciated as I don't want to sink any money into the item until I have some idea of the nature of this shift dificulty.
Thanks All.
Thanks All.
