thanks, it's starting to piece together.. please look at the attached photo of my solenoid(the way I received it)
View attachment 197891,, i understand the connections on the two larger poles are correct (one to positive battery, the other side to positive on starter) . On my pic, the negative ground from battery is connected to one of the small terminals.... is this wrong ? the diagrams I see, the small terminal nearest the +starter side of the solenoid goes to the cut-off switch, the other small terminal on the battery+ side attaches to one of the terminals on the key ignition switch
UPDATE : if my assumption is right, this is wired wrong , the intention was to bypass the safety switch - which creates new questions - how does the safety switch work, how is it activated and why would it be bypassed? ( this boat came with a geri-rigged merc controller for gear and throttle, so there is no neutral safety switch mechanism available)
UPDATE: I know see that the neutral safety swich has nothing to do with the gear/throttle control box,, I see that the switch is below the flywheel and as the gear shift physically moves it either opens or closes that safety switch. My safety switch has another lead on it which is not attached,,, should it be attached back to something (one lead is to come from the cut-off switch and the other end is not attached) - looks like a flat connector. I need to have this function working , for safety reasons.
