iamwill1973
- Joined
- Jul 15, 2012
- 53
Ok a 650 mercury I removed from the v178 starflite and installed on a 15' 1970 model glastron has some electrical wiring issues I have to repair nothing serious under the cowl. I also noticed the wiring from the tilt motor to the limit switches beside the starboard side ram on the actual business end of the system is rotted and broke in several places. I saw this unit work a couple times before doing the repower, so I am at a loss with this I do not understand how it works without being hooked up to the limit switches. I have the manual found here http://www.scribd.com/doc/75281168/Mercury-Outboard-Tilt-Manual and I still do not know if it needs to be rewired or not. Could someone please comment advise or just tell your knowledge on this situation? Please!!! Looks like I will have to remove a piston ram to get to the switch box it is mounted in. The cable is extremely rotted but it looks like it only had one wire in it but it should be 2?
