Hillbillywill
Thread starter- Joined
- Feb 18, 2011
- 26
I cant get power from the solenoid to the starter.
Test done and there is power to the battery side of the solenoid (power cable connection and solenoid post). When I turn the key, there is power to the engine harness side of the solenoid post, but none to the power cable running to the starter.
replaced frayed wire from cut off switch to under flywheel and checked other connections. Beating my head against engine block didn't help either.
Suggestions?
thank you.
Suggestions?
thank you.
