1966 Johnson 33hp outboard questions
acdc96
I'm buying a 1966 Johnson 33hp outboard for my 1966 Lonestar. So far all parts have been fairly easy to find. But I can't find a carb kit for it I only see individual carn parts. Do they make a carb kit?
I know it's a long shaft and believe a electric shift. The model # is RXEL-14D.
I plan on rebuilding the carb, replacing the head gasket & head cover gasket, replacing the coils and condensers, impeller, spark plugs, & fuel lines. Any other parts that should be replaced or rebuilt?
F_R
Honorary Supreme Mariner
Carburetor kit for 33hp, 1965-1970 is 18-7010 right here at iboats. Replaces OEM numbers 382050. 382051, 382054. A kit # 18-7024 will also work, but includes a bunch of parts that you won't need.
tomhath
Pressure test the lower unit and replace the seals if necessary.
acdc96
Just to be safe I'll order the lower unit seal kit... Parts for this motor are so cheap and easy to find!!! Thanks all for the replies.
acdc96
Does anyone know of a site that I can download a PDF file of the service manual?
