1966 Johnson 80 hp
mkling
On the bottom of the lower unit near the exhaust is a small hole, looks drilled also there is a small hole on the unit i call the spacer as I do not know what else to call it, this whole is near the forward port bolt it also appears as it is a drill hole. are these small holes drain holes or should I plug them.
Fluid was coming from them, just not sure what they are.
mkling
Re: 1966 Johnson 80 hp
Thank you, wish it mentioned them in a manual somewhere..
