1966 Johnson fd-20c SHIFT LEVER PROBLEM
ECHOSIDE
This past weekend something broke on my shift lever problem is I don't know what. The lever is now very sloppy and will not stay in gear. I can still get it in gear if I play with it but it will fall into neutral if I try to leave it alone. Where is the lock mechanism or lock located to hold it in gear.
THANX
F_R
Vertical flat interlock bar on starboard side of the powerhead. Pivots in the middle, spring at top end.
