I have just rebuild the carbs on my merc 650 because they were pouring fuel out of the main nozzle plug screw. These are side bowl type carbs. I was told the float might be stuck. After reassembly and installation, I'm having the same problem. there is a small pinhole in the bottom of this plug that's dumping fuel all over the lower carb. I can't tell if the lower carb is leaking too because it's soaked from the top carb. <br /><br />Also during rebuilding, i didn't replace the intake needle and seat because the original had a nylon seat. The ones in the kit were solid brass. Should i have replaced them anyway? <br /><br />The engine will start and run for a few seconds and then cut out. After it cuts out, that's when i see the fuel comming out of that plug. I have been using the seloc manual as a guide, but i'm at a loss now. <br /><br />Comppression is at or near 110 for all 4 cylinders. I have good spark and plugs are set at .025 gap per the manual. Any help would be appreciated, thanks
