1966 Starflite 100-s,wet plugs on port side only.
C_hab420
Hi again,
I've been running this motor alot and it hasn't actually fouled any plugs to the point where it wont run.It runs good through the throttle range.My question is,what would cause the port side cylinders to be wet after it runs?The starboard plugs look as a two stroke should.The compression still checks out at 100psi on all cylinders.I can't figure it out.Could this be a timing issue?Since the other plugs are dry it couldn't be an ignition problem,could it?All cylinders fire strong.
Thanks for any advice,Chris
