dozerII
Thread starter- Joined
- Oct 25, 2009
- 6,527
I am finaly getting around to looking at the leg on a friends 40 hp model RK29E
ser C530489. Every year he has had to change the oil a couple of times because it gets milky. I did a pressure test on it and found no leaks at 14psi, which it held for three hours. When I pressureize it, it pushes the drive shaft up a bit and will try to push it out. This morning I took the water pump off and there is a bad groove cut in the drive shaft where the top water pump seal rides. I then pulled the drive shaft out and it has a bad groove cut in three locations. Above the pump, below the pump and then one more below that. Is it possible the water that is getting into the oil is being put there by the water pump pressure pushing water down the shaft? Any help would be appreciated.
Thanks Glen
Thanks Glen
