1967 6 hp viking/chrysler/seaking/westbend
scorpio65
I have 1967 Viking 6 hp no.64801 made for Eatons of Canada by Chrysler. Gear case is taking on water. I have searched all over and can not find a place to get the seals I need. Can anyone steer me in the right direction? thanx
Nordin
Try Franz Marine, he may have seals/seal kit if they are available.
scorpio65
Mastertech says they can't help me and have not heard back fro Franz. Anybody else have suggestions?
harringtondav
No OEM, auto or marine, has ever made their seals. In rare case some seals may be proprietary, but most are available through Motion Industries or other seal distributors as standard seals. Seals are sold by shaft outside diameter (OD), the bore diameter - seal outside diameter and thickness/height. Measure all of these dimensions and do a web search. If you get an odd size, convert it to mm. If you get close within .002 - 003", try the seal. They are forgiving and inexpensive.
jerryjerry05
If the seal hasn't been destroyed??
You can possibly use it again??
Put shims under it, or turning it upside down can sometimes work??
Not the best way but??
Also take it to a Grainger store.
They might have something you can use??
scorpio65
Info for other searchers. Franz does have a gear case seal kit for my 64801. $59 usd.
