1967 60hp resistor wire
Lion hunter
The resistor wire from the engine plug to coil is completly rotten. Does the actual resistor run from the key switch to plug, from plug to coil, or the entire length from switch to coil? Is there a source to purchase resistor wire?
I have read that if the resistor wire is replaced with regular wire then a standard auto coil with internal resistor can be used. Has anyone tried this?
Next scenario can I retain my marine coil, replace wire with standard wire and install a ballast resistor inline. My preference as I think the coil is good would be to replace the resistor wire if possible.
