coloradorookie
- Joined
- Mar 18, 2006
- 12
Hello all, <br /><br /> I need help,i have a 1967 650 65 hp merc type I ignition, magneto and points, that wont run under load, heres whats been done:<br /><br />carbs rebuilt by reputable well recomended dealer,<br /><br />new fuel tank, line fittings, primer hose etc, filter as well<br /><br />linkages checked by pro, adjusted as well<br /><br />leak down down by shops as well, <br />they said less than 5percent on all 4<br /><br />but i just cant get it to max out under load.<br /><br />prop is fine as confirmed by three separate local prop shops, only a "12"<br /><br />boat not all loaded, 16'5" bow runner,fiberglass<br /><br />but i just cant get it to run fine on the boat, test tank she blows the water out, has 3 mechanics confused. i know cars not boats, but i suspect the coil and or points, does this sound about right, is there a way to test the coil if i pull the magneto assembly? bought a seloc manual no real help.<br /><br />hate to scrap it but is it worth paying to rebuild it or am i missing the obvious?<br /><br />thanks all!
