gavin dunne
Thread starter- Joined
- Jul 17, 2005
- 23
Hi. I have a 1967 6hp Johnson, which I am trying to revive after 20years of lying up. I had one spark on top cylinder and would run for 1-2 seconds when some fuel was squirted into the cylinder before I touched it. I have now replaced the coils, points and condensers, also rebuilt the carb, replaced plugs and the impeller. Fuel pump checks out for no leaks. I have two sparks now and fuel getting to the carb but it still wont start. I have read thru the faqs but dont know how to progress. Any ideas?. The carb seemed clean as a whistle before cleaning and I didnt notice anything on the reeds although I dont know what they should normally look like. One thing which worries me is that when installing the armature plate I noticed that the ring on top of the crank shaft to which the plate is attached by 4 screws can rotate freely around the crank shaft. Is this normal? I would have thought that the armature plate position with respect to the cam would be critical and that if the plate was free to rotate then the timing of the points with respect to the piston stroke could be out. Am I worrying about nothing? Thanks in advance
