1967 75hp chrysler out board motor
harleyway
Hi Guys
I have a 1967 75hp chrysler outboard motor that keeps breaking the timing belts. The fly wheel was damaged and a new one was put on but it still happens. When I tighten the flywheel nut down it seems to go down too far and rub the bearing . I would like to know how to raise the fly wheel up if that is possible or is there another way to fix this problem. I have allready changed the crankshaft because I thought it was wore down so the flywheel went down to far. If you have had this and found the reason I would like very much to hear from you. Thanks
Harleyway
