Brianjason6
Thread starter- Joined
- Aug 21, 2009
- 116
I've found that the stock prop is 8.25x8.5 but first I need to know if mine is bad. It has a good shear pin behind it but I can turn it by hand. The shaft doesn't move. Should I be able to do that or has the prop been damaged?
The actual problem is...I can run the motor up to about half throttle with no slipping. Beyond that the engine over revs and the motor doesn't propell. If I slow back down it works again. My thought was that the propeller may be damaged causing the shaft, at high rpm, to outrun the prop. Am I even close? If so I could also use some help finding a prop....reasonable...Thanks All.
