1967 9.5hp Johnson revs up
dfrants
my 1967 9.5 Johnson starts and idles great, but when you open her up at about half speed she wines up like the prop is slipping. I checked the drive pin inside the prop and that's good.
Sounds like the rubber hub in the prop is slipping.------Perhaps mark the hub and the outer part.------Put the motor through its paces and see if marks have moved.--Try another prop !
