Fredrunabout
Thread starter- Joined
- Jul 16, 2015
- 13
I tried searching the forum for this topic but can't find the exact situation. I have a 1967 Johnson Big Twin 40 hp. I had the lower end unit replaced last fall with a brand new water pump. I just put it in the water for the first time and it won't go into forward gear. Reverse and neutral are okay. I can disconnect the cable and manually pull the lever down and get it into forward gear but it won't stay when I let go. I tried adjusting the cable but no luck, it just doesn't pull it down far enough to get into forward gear. In a previous post with a similar issue but different engine, someone replied by saying the drive rod in the lower unit may need adjustment, but there were no details. I could bring it back to the shop that did the initial repairs, but that may take a long time. Just wondering if it is something I could do.
