1967 Evinrude 60HP - where to begin?
statzk
I recently bought my first boat, a 1968 Silverline (not sure of the model). It came with a '67 Evinrude 60HP 4cylinder (model 60753A). I was told it ran well and was propperly winterized when last used. Had been stored inside, covered for the past 8 years. Engine and boat are in excellent condition, just wondering what all I should do before I attempt to start the motor.
I am planning on:
compression check
Cleaning heads/pistons of carbon
new plugs
new lower unit oil
Other than that is there anything I need? I still am looking for an OMC service manual for the motor. Not planning on using the boat/motor until the spring.
Thanks in advance for any help!
~Kevin
Joe Reeves
Re: 1967 Evinrude 60HP - where to begin?
Remove all spark plugs. Check spark whioch should jump a 1/4" gap on that model with a strong blue lightning like flame.... a real SNAP! Does it?
Spark plugs can be either J4J or J6C plugs, gapped at 030. The J6C may provide improved performance.
Set the point gap on the high lobes so that a .020 gauge will pass thru but a .022 will not.
Sitting for eight years..... remove, clean and rebuild that carburetor. Make notes and take pictures of all linkages etc before removing it as a small error in linkages will result in poor perormance.
(Carburetor Adjustments - Older V/4 Downdraft Carb)
(J. Reeves)
NOTE: The early model downdraft carburetors incorporated "Adjustable High Speed Jets". The later model downdraft carburetors used "Fixed High Speed Jets". Follow the below instructions accordingly.
NOTE: If you do not have adjustable high speed jets, ignore those paragraphs pertaining to same...... BUT do make sure that you manually inspect and clean the two brass fixed high speed jets which would be located in back of the two 7/16" slotted hex head bolts in the bottom front portion of the float chamber.
Lift the center High Speed Control lever and turn it so that the point faces forward, resting on the high ridge. This will disengage the lever control gear from the individual high speed jets (slots). Have the slow speed needle valve knobs installed upside down so that they can be turned without encountering any obstruction.
Gently seat each of the High Speed needle valves, then back each one out one (1) turn. Gently seat each of the Slow Speed needle valves, then back each one out one and one half (1-1/2) turns. NOTE... have the jam nut on the s/speed needles snug so that vibration won't have any effect on them, but loose enough so that you can turn them without a great amount of effort.
(High Speed)
With a reliable person at the wheel, and one kneeling in front of the engine, start the engine (yes, it will run lousy with the above initial needle valve settings), put it into forward gear, and apply full throttle. Start with the High Speed adjustment on the left using a screwdriver that properly fits the slot.
(High Speed Adjustments)
At full throttle, with the proper size screwdriver, slowly start turning one of the H/S needles in segments of 1/8 turn, waiting momentarily for the engine to respond, then repeat turning. You will reach a point where the engine will start to die out. At that point, back that needle valve out approximately 1/4 turn. Now, go to the other High Speed needle valve and repeat that procedure. At some point in that 1/4 turn out, you will find the smoothest high speed setting (you can now lower the throttle rpm). That will have both high speed needle valves set correctly, and at that point you can lift that center lever adjustment of that high ridge, keeping it lifted until the point is facing the engine, then lower it into its proper position. (When you turn that lever now, you're adjusting both High Speed needle valves at the same time.)
(Slow Speed Adjustments)
Now, lowering the rpms of course, take the engine out of gear and set the throttle just to where the engine will stay running. Again, in segments of 1/8 turn, slowly start turning in one of the slow speed needle valves, waiting a few seconds between each turning for the engine to respond. As you turn the s/speed needles in, the rpms will increase..... and as it does, lower the rpms to where the engine will just stay running (otherwise the rpms will climb quite high). You will reach a point whereas the engine will either start to die out or it will spit back (sounds like a mild backfire). At that point, back the needle valve out 1/4 turn. Repeat the process with the remaining slow speed needle. Again, at some point in that 1/4 turn out, you will find the smoothest setting. When finished, tighten the jam nut somewhat, then remove and reinstall the s/speed knobs correctly (right side up).
When time permits, visit my store (copy/paste) at: stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc
HighTrim
I would also drop the lower unit and inspect the water pump, that impeller definately needs to be changed after sitting that long.
statzk
Thanks for all the help guys!
I will certainly check out your store online. Where is the best place to get an OMC repair manual for the 60HP V4? I have been watching Ebay but I have not seen an OMC manual go by, just the "generic" manuals that cover lots of years (Selec)...
So added to my list are:
Get rebuild kit for carbs and rebuild.
Tune carb (obviously I planned to do this before).
Drop lower unit and replace impeller.
Sounds great and not too much money or time- I have all winter, not going to try and mess with it now, it is starting to get cold already here in Indiana!
Thanks again!
~Kevin
HighTrim
For original reprints, visit outboardbooks.com. Usually cheaper on ebay though if you keep an eye out.
tashasdaddy
if i remember correctly it is a fat 50hp tuned up power head, with a 75 lower unit. almost indestructable. this is the best i found on ebay, 110186185926. sending link to someone else that may have a lead for a manual.
Gary H NC
Here is the original factory manual,good price!! The seller is a friend and a great Ebayer.
TD,is clickable Ebay links allowed?
"http://cgi.ebay.com/ebaymotors/1967-60-HP-EVINRUDE-FACTORY-REAL-SERVICE-MANUAL_W0QQcmdZViewItemQQcategoryZ26453QQihZ010QQitemZ200159666435"
edit: no Gary
F_R
If it really was properly prepared for storage, I suggest you just gas it up and see if it will start. If it won't, then troubleshoot it to find out why and fix that item. Doing a bunch of unneeded repairs will only confuse the issue.
If it was properly prepared for storage, the gas would have been drained, thus probably no need to tear into the carb. Hopefully, they also drained the tank and hose, otherwise it will be hopelessly full of gum and rust. Just run down to WalMart and get a new one (or better yet order one here). The oil would have been changed, thus just make sure it's full. However, do change the water pump once you find out it will run. After sitting 8 years the rubber isn't going to like being flexed.
BTW, if you do get into the carburetor, don't remove the venturis. They require a special tool to center them over the bores.
Evinrude Boater
I keep reading about this special tool and I just don't understand the importance. I've had my carbs apart with normal tools and they seem to work great. Am I just lucky or too ignorant to know better?
Statzk: Check the fuel lines or just replace them to be safe. You don't want an engine fire first time out. They're rubber and just like the water pump, they deteriorate over time.
F_R
It will work if you just slap it together any old way. But it will work more efficiently if you use the tool. And of course there is always luck too.
statzk
The tank I have already inspected- looks brand new inside. The motor (and the entire boat pretty much) look more like a one or two year old motor, not like something 40 years old! I really lucked out, especially considering the price I paid for it ($350 including trailer).
The tank was drained, even the plugs and wires look brand new. Under the hood the motor is cleaner than my car, and my car is only 2 years old.
I do want to go through the motor, just to be sure what I am getting into, but part of me does want to put gas in and see if she will fire up... I am betting it will.
Maybe I will do that in the spring, then just replace the water pump/impeller and tune the carbs. Tear into the motor if I have to... This winter I will be lifting the boat and repainting the trailer (it is solid, but has a bit of rust and I want to repack the bearings) and paint it to match the boat.
Thanks again for all the help! I have been wanting a boat for 20 years and finally took the plunge (and for $350 I couldn't pass it up).
~Kevin
Joe Reeves
The venturis should be centered as there is a dividing vane in the intake manifold just below the carburetor. The purpose of the vanes is to divide the fuel evenly between the two related cylinders being fed, hence the special tool to center them perfectly.
However, it seems that most of the boaters that I've heard from that do not have that special tool have not encountered any performance problems after rebuilding their carburetor.
When the tool is not available, a good practice is to scribe a line around the venturi housings into the lower carburetor body before removing them. This increases the chances of reinstalling them perfectly.
