mottt
Thread starter- Joined
- Aug 25, 2009
- 80
Hello out there, I first want to thank a lot of you out there who have posted replies to help other frustrated boat owners. I have been reading some posts which have helped me greatly.
I have a 1967 6hp Evinrude Fisherman - 6702
I got it at a yard sale for $50 with gas tank. The previous owner said that it ran 2 - 3 years ago. I drained the gas tank and cleaned it thouroughly and let it sit for 2 days to dry out. I got new gas and I built a mount for it and attempted to see if it would start with no luck. I have rebuilt the carb and set the HIGH speed to 1 full turn out and the LOW speed to 1.5 turns out. (to adjust the high i have to take the carb completely apart)
My dad came over a few days later and got the motor running after about 15 minutes of tugging on it. He had to keep messing with the choke and throttle to keep it running but IT RAN!!!
I have replace the old gas can, hose and gas - with 50:1
A few days later i could start the motor with a couple tugs and it would idle, but would not go into high RPMs. I tested compression with both plugs out and it is 90 on both cylinders. After 20 minutes of it idling, I did a gravity test with a funnel straight into the carb input (not the throat) and it would idle and run at high RPMs. Which would indicate a bad fuel pump.
I got a new fuel pump and attempted to test it again. I had as much trouble starting it this time as I did the first time. And it wouldnt stay at an idle.
WHAT IS GOING ON?
I read that these old motors once cold can suck air through old seals and still give you a good compression reading. When they get warm the seals expand and seal correctly. Is this true?
I am under the assumption that when the motor ran a idle and high speed when I did the gravity gas test was a coincedence.
I am at a stand still right now because I don't know of what more I can do with it. I want a pro to fix it, but im not sure if its worth the money.
Please help
WHAT IS GOING ON?
Please help
