1967 Evinrude 85hp (tem. guage)
cblguy4u
Howdy I was wondering if the temp guage for the motor is just a regular one you can buy at an auto parts store?Thanks for your time.
R.Johnson
Re: 1967 Evinrude 85hp (tem. guage)
I believe that engine use's a red warning light.
cblguy4u
How do i check if the red warning light is working properly?
R.Johnson
The temerature sensors are mounted in the cylinder heads, They have a knife connector with a rubber sleeve. With the key on, slide the sleeve back, and touch connector to ground. The light should come on.
cblguy4u
cool ill give it a try thanks alot.
