1967 evirude 80 hp (starter trouble)
cblguy4u
Howdy it's been a few months sense i started my motor, it started fine. now when i try to start it the starter won't engadge to the flywheel. i tryed to lube it up. does anyone know what i should do?<br />thank you for your time.
Joe Reeves
Re: 1967 evirude 80 hp (starter trouble)
If the starter is turning fast as it should, I would suspect that it may have grease on the bendix which would gather dirt which would jam it. If this is the case, spray some WD40 on it to free it up.
cblguy4u
thanks Joe . ... you meen spay it down were the spocket is on the starter?
cblguy4u
i have tried wd-40 on the starter. the starter turns fine but it won't engage to the flywheel.??? i don't know.HELP
Joe Reeves
I'm speaking of the bendix drive, not the starter. The actual bendix drive gear and spiral support that allows the gear to travel upwards into the flywheel teeth.
cblguy4u
right on thanks joe i'll give it a try
cblguy4u
thank you for your help joe. shes working fine now. YES!!!
Joe Reeves
Hot Darn.... Finally fixed one!
