1967 folding Johnson; should I use it or sell it?
fat boy
I recently purchased a 3 hp johnson that folds and has a case. The motor is a 8 out of 10 and the case is a 4 out of ten. I don't need the folding capability. I do need a lightweight 3 or 4 hp motor for an inflatable. Should I sell this to someone who collects these very unique motors and buy a more conventional motor, or just go ahead and use it? I would like a neutral gear.
Your thoughts please.
tashasdaddy
Re: 1967 folding Johnson; should I use it or sell it?
use it, it is not a collectable, many of them out there, i have one also.
fat boy
Thanks for the note. I suspect you are a pretty knowledge guy. Anything you can share with me regarding this little 3 hp folding Johnson would be most appreciated.
Kind regards,
TN-25
The 3s are great little motor, well suited for your use. There is no weight penalty for the folding shaft. Most parts for that motor are still available. The 3 had a long run (1952 - 1968), then carried on as a 4 into the 1980s. Your 3 uses the cleaner 50:1 mix (since 1964 models) and was the last of the metal cowl, integral tank 3s (1967 was).
If you really need a neutral, a 1980s Johnson 4? would be good (but they have separate fuel tanks). An old (very old) Johnson 5 model TN has a neutral lever and integral fuel tank, but they are a bit too old to be a practical motor due to parts availabilty (I have a very nice one though). Mercury made a very nice little 3.9 / 4 /4.5 horse single throughout the 1960s and 1970s that came with a twist grip throttle and F-N-R gear shift, but I think the Johnsons & Evinrudes have them beat in terms of parts availablity today.
My advice is that you keep the motor. I think you'll enjoy that little 3. Just make sure that you maintain it properly (periodic impeller replacement, plus keep it lubed & tuned). My dad bought that very same motor new. Today my older brother has it.
fat boy
Cam,
Thanks again for your knowledge and your time. I will take your sage advise.
Kind regards,
fat boy:)
