Re: 1967 IMP Aztec -- Thoughts and suggestions for Rebuild maybe repower
that would be for a normal mix, but what about due to the higher temps, should it be a little less MEKP to give a slightly longer work time?
and last one, for sealing the plywood on all sides first, is 1% not enough MEKP so that the wood can absorb it and still cure?
that should be it for now. i will be bolting it up here a just a little bit to dry fit it that way and see, then all the plywood gets sealed later this evening when the temps go down some.
