dozerII
- Joined
- Oct 25, 2009
- 6,527
A friend has a 67 40 horse johnson that is taking water in the L/U. He changed the oil and it was milky. I told him I would take a look at it so I pulled the unit and brought it home. This morning I drained the oil and it was mily again and has not been in the water since he changed it so it need flushing out. I made an adapter to fit the vent hole and put in a tire valve, set the L/U in a tub of water over top of the water pump and put 15psi in it. No leaks were visible. I got called to work and left it in the tub till I came home 7 hours later and it still has 15 psi in it. What am I doing wrong checking it, or where could the water be coming from?
Any help would be appreciated.
Thanks Glen
Thanks Glen
