1967 Johnson 40hp looky what I found...
nearpar
Received this 40hp Johnson outboard from my neighbor who told me "it just needs a flywheel " he received it as payment for a small welding job he did for someone about 10 years ago. The motor has been sitting in his barn for the last 10+ years. Fontunately for me I got it for free. I was thinking a tune-up, a new flywhell, and an impeller I will be on my way!
A couple days later I hoisted it up on my shop crane and tried grabbed the flywheel nut with a large wrench and it would not budge. I removed the cylinder head and the bottom piston was frozen to the cylinder wall. At this point the motor was probably good for parts. I tested the starter and the generator and they were working. I went to remove the lower unit and it was full of mouse droppings, acorns, and nesting material. The entire lower unit had at least a 2 gallon jugs full ! They must have crawler up the exhaust tube and then down into the lower unit. ( this was a long shaft motor ) So my lesson here is when you are actually going to spend some money on used motor that has been setting around and the owner claims it ran fine a few years ago, you need to make sure your not buying a new boat anchor !
Daviet
Re: 1967 Johnson 40hp looky what I found...
When I am looking at a used engine to buy, if it can't be run, it's a no sale unless it is really cheap.
Haus
at least it was free
nearpar
Also wanted to mention that looking from the outside of this engine you would not have guessed that it was that bad....
kodibass
Dang, well parts is parts
