1967 Johnson 9.5 MQ-13M Hot to set points
300winchester
On the flywheel it says
set points here
set points here B
can anyone tell me the procedure to set the points
thanks in advance
Chinewalker
Re: 1967 Johnson 9.5 MQ-13M Hot to set points
Set the points at .020" with the point cam rider aligned with the keyway on the crankshaft. Set the same way for both sides, and voila - DONE!
