1967 Johnson prop seal removal
kazek
Hi.i am in the process of changing seals on lower unit of 60 hp johnson'67.after changing drive and shift shafts,I am stuck with prop shaft seal.as far as I can tell needle bearing has to come out.is this right?
Another question i have is gasket between lower unit and mid section.does it has to be there.what gauge of gasket,as I am planing to making it from gasket sheet.this is my first time removing lower unit on Johnson.thanx in advance
