Spiderhole
- Joined
- Oct 29, 2014
- 118
Hello, I picked up this old school motor to compliment my small Thompson wood boat to putt around in. A few questions...
I have two sets of controls. I have a white one and a black one, both appear to have the connecter that matches the motor. Will any Mercury controller with the correct connector work? The two I have are both whipped - the white one had a key and was working well enough to wire it to temporarily here the motor turn over, I believe the neutral switch is broken? If I was going to use either of them I would have to rewire everything.
What is the correct controller for this motor? I will use anything that is reliable.
The previous owner said he had replaced the impeller at some point. Are there new aftermarket parts I should consider addressing now? The motor has only ever been used in fresh water.
Thanks!
Chris
Thanks!
Chris
