1967 Starcraft Jet Rebuilding
jbcurt00
Originally there were thin aluminum strips below each of the seams in the decking, to tie them together as you're suggesting, definitely put something below the seams
catbones
Great, perfect. Didn't know and none were there to begin with. So now, since the floor is attached, maybe metal attachments at top of seams before the carpet goes down.
jbcurt00
Whatever you put above will telegraph thru the carpet
Thin aluminum sheet might work, never seen anyone put them on top
catbones
No Title
Some more progress photos, 5200 very messy :)
I also decided to go with the wooden backing on the transom for the engine mount. No real reason just what I had at hand. Sealed, 5200'd and mounted. Also scuffed the new interior paint, that will need a redo.. grrr
BTW, anyone know why I have three holes for the splashwell vs two???
catbones
Never mind, figured out that the third hole is for the thru hull outlet. Oops!
Watermann
Having gone through a few construction tubes of 5200 I can say it has earned it's nickname "Pelican Poo". :lol:
catbones
That's funny. Love the work you did on Chieftain, really amazing job. Can't wait for my own splash and maybe another upgrade to something larger in future restore.
Watermann
Thanks for taking a look at my Chief. I miss too many of the SC rebuilds when they're tangled up in the masses at the resto forum. MBS runs strong with these boats.and having 2 of them is the only way to go. I'm always looking for another one but then I would have to sell my little SN.
Keep pressing on and you'll be skimming the waves in your little Jet and turning some heads! :thumb:
catbones
Thanks! I hope so as this is my first rebuilding project and theres a few things I would do differently, but I guess you learn with time. MBS??
catbones
No Title
small update....
Anyone know a good place for decals for the Johnson 33? I'm not spending $45 cheapest I found on some decal ... I'd like to repaint my cover and all
catbones
No Title
so i can either go with decals A... and keep the motor strength to myself and all guessing
catbones
No Title
or i can add more style keeping the "6" out of it and use these...
Watermann
Multiple Boat Syndrome :lol:
I like the seahorse decals way better.
catbones
Hi guys, I'm having an issue... I'm trying to mount my motor back into the boat. The top part has those tightening type clamps... But at the bottom of the mount, where the bottom pushed against the transom, I see there is two holes for bolts (not sure what size) but the problem is, I don't see enough room to tighten a bolt.
Can someone with similar motor or mounting snap a photo or diagram. Thanks in advance.
TruckDrivingFool
Are talking about from the inside or outside? Not sure of your 33 but on mine(50) the outside brackets hold the bolt heads and I just tightened the nuts up inside under the SW.
catbones
Referring to the outside... On the inside top of the transom I got the tighten by hand sort of things, no bolts or anything... But when I look at the bracket that pushes against the transom rear outside back of the boat, about an inch from bottom of that bracket, both sides, I got two holes, which looks like possibly another set to hold that down? I'm not sure. I'll take a photo and post it next.
catbones
No Title
