Re: 1968 15' Starcraft Jet Star Rebuild
Great point Lon!
Yah, just cutting the bow out would make for a floppy noodle of a boat. But, I have a plan my friend!
See the photo of that old green Mariner up there ^^^^^. See how there is lots o' aluminum left on the gunwales and a big hunk right at the bow nose? Yah, that should provide lots of structure for the hull. You'll also notice in that photo there is a bench up front there. I'll be adding a casting deck/bench sort of deal that is fastened right to the hull. Once I do that, the hull should be bomber.
Thanks for checking in buddy!
So I found myself nosing around over here the other day...
http://forums.iboats.com/showthread.php?t=360236
I read through the report and have myself thinking about the four strokes now. Huh.
I wrote 'em off as too expensive and too heavy. There is no doubt I'd be paying for that technology but as I am shopping around I am seeing that the four stroke is sometimes within $500ish of it's two stroke brother. I am also seeing that the four is right around 50 lbs. heavier that the two. Kinda sorta equivalent to an extra 8 gal fuel can. I think I can find that weight savings somewhere else in the boat.
That report is telling me that the four strokes edged out the two on top end speed, and whooped em on noise and fuel economy.
The lower dB's would be great on a little 15 foot boat like I am building here. I think it would be something I could quickly come to appreciate.
It seems like the fuel economy would recoup difference in initial investment in pretty short order too(so long as I get a good deal on the front end).
Hmmmmmmm.....
The hard part will be settling the $$$ thing though, I do have some thick yankee blood.
I am seeing that I can pick up an older 50hp two stroke, no T&T, good shape for $750ish. Add in the T&T and make it a more up to date model and I'm at about $1500 - $2000. Make it a four stroke and it looks like I am sitting at about $2000 - $2500 range.
Ouch.
Yah, maybe I'm not thinking four stroke. Or, T&T for that matter. Old school, tilt it up with manual power may be the way to go for my budget.
Good report anyway
