1968 55HP Johnson Upper Crank Seal Replacement
hulvdog
It appears that this seal is leaking, due to oil appearing in the points area. Can I remove and replace this seal without having to take the powerhead apart? Can it be carefully pulled/pryed out? If so, what's a good method to avoid damage to surrounding parts?
