Just an update on a post from months back. I had my motor rebuilt and later found out they used 1970s style flat tops. There was some concern here that the loss of the dome would lower compression ratio drastically causing poor performance.
Well, my inpatience and curiousity got the best of me and I went searching for a lake that was thawed. The engine runs very strong! Top speed was 29 mph, only 2 mph lower than what I got out of my previous 88 60hp. The acceleration is roughly 95% that of the 1988 60hp. I was amazed that the performance was so strong, compared to how it run before the rebuild (had the same accel as my 68 40HP).
I did notice it was a bit rough at mid throttle. Could this be low speed needle adjustment??
Also, throttle does not quite return to idle speed stop. Cable adjustment the issue?
Thanks.
Thanks.
