1968 9.5HP Where is this water comingfrom? W/PIC
oldcatamount
Re: 1968 9.5HP Where is this water comingfrom? W/PIC
The "rocking back and forth" is not normal. Sounds like there are some missing bolts that would hold the pwerhead in place. Under the pwerhead, there is a gasket and seals that are very important and need to be in there.
Wishiniwuzfishin
water.....
Daviet
Is the engine overheating? I wounder if the exhaust hose from the powerhead to the cowling is leaking on the bottom side. Is the escaping water warm or cold? Use a flashlight and look down from the top around the covers and see if you can see a leak. Broken motor mounts will let the engine flop around in the cowling.
oldcatamount
The water tube leading up from the impeller to the powerhead is most likley disconnected or broken off. You will need to remove the lower unit and take a look up inside the exhaust housing. There is also a rubber grommet at the impeller that may be leaking water and also a grommet half way up the tubing going to the powerhead that may be leaking.
Wishiniwuzfishin
water...
ultra353
Its completely normal for the water to be coming out there. There are drain holes in the exh housing for the water that gets in the housing to exit. If you can move the powerhead back and forth more than 1/2 inch than you most likely have the common broken front motor mount
F_R
Honorary Supreme Mariner
NUTS and Phooey!!!
#1, that water is coming from two big drain holes in the exhaust housing. It originates from the water pump, coming out through the hole that the drive shaft goes through. It is absolutely normal!!! However, if the pump housing is badly worn, it will leak more. If those drain holes weren't there, the water would go up the drive shaft tube and damage the powerhead.
#2. If you can grab the flywheel and move the powerhead fore and aft more than just a rubbery feel, the upper front motor mount is broken. That was a very common problem with the 9.5 motors. It is a major job to replace it for a pro, and very intimidating for a novice. I've replaced so many of them that I almost could do it blindfolded. I was a dealer mechanic, servicing a fish camp full of them.
Wishiniwuzfishin
water....
F_R
Yes, my picture is the exhaust housing, inside the outer "shell". You can see the bottom end of it extending below the shell, where your picture shows the water running out.
A normal powerhead will have a cushioned feel, but not flopping around loose in there. A broken mount will allow the powerhead to flop fore and aft a good half inch or more.
Wishiniwuzfishin
water..
