1968 9.8HP changing plug wire advice needed.
32251
Took the flywheel off to see what was needed and found that the post that holds one set of points on was loose...fixed that.
Now I want to change the plug wire, but the coils are riveted on and you cannot just unscrew them and R/R the plug wire. Before I go to trying to figure out how to unbolt the entire plate that the two coils are riveted to, I wanted to ask the experts what is the correct procedure to replace plug wires. I don't think there is enough room to work from the underside without removing the assembly to pull each wire out and reinsert, but maybe I am wrong.
The wires are original and cracking and damaged areas have been taped up...it's time to change them!
Thanks for any advice.
