1968 Boston Whaler 13
JBooth
I got a good deal on a 68 13' whaler. It is a bit of a project but not to bad. I was wondering, before I buy, if a '05 15 hp Johnson would be a sufficient outboard for this boat. I normally fish with one other person and would like to be able to move 25mph+ due to distance. Will I be able to reach this? Any help would be appreciated. Thanks, John
steelespike
Re: 1968 Boston Whaler 13
No I don't think 25 is possible with 2 and gear.Is it a 2 stroke or 4 stroke do you know the gear ratio?You can figure gear ratio by pulling the plugs,Put a mark on the flywheel and count turns of flywheel till the prop goes around once. probably be about 2 times. My research came up with 2.00,2.42 and
1.92 ratios,so you'll have to look carefully.
The 15 might do 25 with one and a light reasonably fast boat.
With very careful setup and minimum load you might get 20 or 21.
tpenfield
We used to run 40 hp on those things back in the 'old' days. 15 hp would be way light. It is a heavy boat, but with enough power (30 hp +) it will get out of the water and fly.
JBooth
Thats what I was afraid of. I have it on a 15 foot jon boat that weighs 275-320lB alone. Fully loaded (450-600lb depending on who I take) it will run 27-31 mph. The Whaler is shorter and wider. The Johnson is two stroke...not sure on the gear ratio.
JB
A Boston Whaler Sport 13 (console steering) is rated for up to 40HP but performs very well with a JohnnyRude 25. Mine would cruise at 23-25 with three aboard.
As a tiller boat, however, the max HP rating is 20HP. You might get 20mph if she is properly rigged.
Of course she is heavy compared to a tinny or a jon. She is not a light skiff, she is a serious fishing boat. I have seen them 5 miles out in the Gulf Stream.
tx1961whaler
JB;3610621 I have seen them 5 miles out in the Gulf Stream.[/QUOTE said:
Didn't you see me wave at you?? ;)
I have had a 40 on mine for many years, but I started out with an 18 on it when I was a boy. It would scoot along with the 18, but both me and the hull were lighter then.
Home Cookin'
I still have my '64. Grew up with the original 18 and it was fine. did some skiiing but then I ws a skinny 14 year old. Recently replaced with a merc 200 and it's still right fast.
Growing up, though, the guys with the 33 did great. Now, if I had the choice, i'd rig with a 25 for general purposes, 40 for speed and skiing. All of course with a console.
Originally, with the 18, we'd leave the plug out at night and it was self bailing. No battery; 6 gallons gas amidships. KISS
The 15 will be ok for putting around and you should get on a plane solo. They were often rigged with 9.9's for utility use.
JB
Was that you? Did you have 2 young girls and a wife with you? I remember heaving to to watch one of the girls fight a schoolie mahi mahi that thought it could fly.
Of course that was 1984, so maybe it wasn't you.
tx1961whaler
No, I was still in college in 84. Much more lake fishing and Intercoastal stuff in C. Fla then. Did the "near stream" stuff off West Palm in 87-90. Of course the blue water can be right on shore there.....big Wahoo, little boat. :facepalm:
The little Whaler can normally take much rougher seas than the operator can take. It's like riding on a cooler top with a motor...and about as comfortable and wet as riding on one......
