JohnnyGuy
- Joined
- Aug 24, 2017
- 196
Hey all,
So I'm not REALLY experienced with gearcase resealing, this is only my second one I've had to complete.
I had a leak at the shift rod on the gearcase of this '68 6hp, so I just ordered a new gearcase reseal kit from sierra and redid all of the seals.
Well, while removing the prop shaft seal, I marred the surface of the housing with the seal remover I was using. When I put the gearcase back together, it was definitely leaking air during pressure test in the marred area, so I purchased a new prop shaft seal and took the gearcase back apart and l removed the new one I just put in. While I did put some 3M 837 around the perimeter of the inside of the housing before installing the seal I'm wondering if I should have done more, or maybe I completely messed the housing and I should just look for a new one. At $25/prop shaft seal I don't want to keep messing this up.
So before I go and make the same mistake again I thought I'd ask for the opinions/advice of some of you guys here who are much more experienced with this than I am.
Photos of the seal housing after I removed the one I put in yesterday that was leaking between the outside of the seal and the seal housing, attached.
TIA
JG
TIA
JG
