kawaboy-zx11
Thread starter- Joined
- Mar 1, 2009
- 109
i have a 1968 johnson 20 HP and i noticed today that when i am going along at a steady pass, the motor stars to bog down, if i pump up the primer bulb it starts running good again, would you say it is a fuel pump problem or a fuel line leak? im not sure if sucking air into the fuel line would cause this, but my johnson fitting SOMETIMES has leak where it goes on the motor (sometimes when i squeeze the bulb gas will squirt out at the fitting). also sometimes the bulb will get hard easily and sometimes it take a lot of pumps. Thanks
