1968 Johnson fuel pump ref #
mars bar
I'm trying to buy a new fuel pump and all I'm getting is " fits part number this and that." Doesn't tell me make or model. Where do I find a number for my existing pump. Nothing but a casting number on the back plate...318374 D2 Thanks Mars bar "mostly nuts"
Honorary Supreme Mariner
There is very little that can go wrong with these simple pumps.------Usually a new diaphragm will take care of any issues.----------What is your motor doing or not doing ?-----Have you tested / tried operating with someone operating the manual fuel pump ?
mars bar
It's an old motor and Iv'e exhausted every option. Found a pinched bare wire on one of the points, Properly set the gap and cleaned the points and rotor, new wires and plugs. Seems like it's starving for gas. Took apart the fuel pump and it's original factory. Diaphragm looks weak and stretched "No rtebuild kits , obsolete..
What hp and have you looked at newer motors with a similar looking pump for the repair parts ?----Do you have spark now that will jump a gap of 1/4" or more.--Have you done a compression test ?
mars bar
It's a 65 hp VXL 14B good spark, and 90 psi on all 4 cyl. No have'nt looked at newer pumps for parts. I don't have enough info. Reference numbers!!!
Just install 438559---This pump is used on a host of motors from your up to motors marketed in 2001
F_R
18-7820 repair kit "should" work. Here at iboats Or 18-7353 fuel pump. Never mind that it says 20-30hp.
