i rewired the trailer with new lights, got the licence plate mounted, so now have to fix the hitch on the truck and rewire light hook up, so i can take it to work get a coworker to put a inspection sticker cant write my own some intrest conflict thing![]()
A while back you posted a picture of your flooring structure... I don't suppose you recall the dimensions of the lumber that was in place?
I'm debating on re-creating that structure for my deck/stringers vs. just updating to a more traditional stringer system.
they put down 4 boards sideways put 2 longways on top of those then draped roving over it creating cavities sprayed it with resin then filled the cavities with foamthese boats are different under the floor than the others i've seen on here, they have glass stringers filled with foam, i had 4 1"X2" boards layed accross the glass stringers then 2 1"X10" longways on top of those and the foam all capped in glassView attachment 145369View attachment 145370View attachment 145371View attachment 145372View attachment 145373they put down 4 boards sideways put 2 longways on top of those then draped roving over it creating cavities sprayed it with resin then filled the cavities with foam
That is quite similar to what I found in mine, although mine were so very rotted out that by the time I reached below deck, everything was basically wood mush. Seeing your pic was exciting because it made some sense of my left over parts and pieces.
After everything I've read here for the last year I am still leaning towards a more modern stringer system. BUT, still undecided. And I have enough of an outline left on my hull to recreate the original system.
My "project" is probably going to take a while to complete, but I hope you pay attention. I have some pretty sick ideas I'd like to pull off that I think you may like, given that your boat is virtually the same as mine!
:facepalm: i just ripped it all out rewired with like 5 wires, so here it is and the horn works too
